There is no such thing as "the same settings" between multiple slicers. The name of the settings might be the same, but how they behave will have slight (but notable) differences. Especially when you think about the 300+ settings that cura has. A lot of small differences can add up to a very big difference.
What you are probably seeing is what I call Z Height Zipper
Its the point in the print where the nozzle moves up (or bed moves down) to print the next layer. This causes a bit of oozing from the nozzle and creates these little seams/blobs/bulges.
I know of no way to completely eliminate this, and every Slicer will put them in different places depending on the model, placement, infill, orientation, # shells, etc.
In Cura, under Shell -> Z Seam Alignment, you can set it to 'Random' and it will spread them around the print like S3D does. I think the default is 'Shortest', which usually clumps them together as you are seeing.
Yeah, I had in mind exactly the same - "Z Height Zipper". I see this option is available in the latest CURA version, because I use 14.12 and there it is not available. Thank you for your advice.
nallath 1,125
DaHai8 74
Edited by GuestLink to post
nrgful 0
