Can you move them with power off? You have to push pretty hard. Don't worry about damaging the steppers as they are extemely strong and you can overpower them without damaging the steppers. You might damage the wood frame or benda metal rod but you won't hurt the steppers.
The Bed is the most difficult to move with power off.
The extruder is easiest.
It sounds like something is wrong.
gr5 2,167
