https://www.youmagine.com/designs/low-friction-um2-spoolholder
This one does fit with 1 Kg spools, I use it with the 1 Kg spools from Extrudr (green-tec)
1
Thanks for the great replies and solutions! I managed to find a reel using the part #1158. Unfortunately, Matterhackers does not seem to have it available. I will be trying to contact them directly for options. I'm sorry that I took so long to reply.
ultiarjan 1,222
The most easy solution is to get the spoolholder that used to come on the Ultimaker2, it's the same as on the 2+, just longer.
Your re-seller can probably still get it for you, and it's cheap (5,- euro in the Netherlands
The Ultimaker partnumber is 1158 (spoolholder long)
geert_2 556
Or you could design one yourself and print that. You just need to copy the part that fits into the back plate, and for the rest you can choose whatever you like.
Or take one of the versions on the internet: there are some with bearings. I have designed one with bearings for my machine too, but it won't fit for yours, as it only fits exactly one standard spool of 750gr.
