Custom Printer and dual extrusion
siquenique
Posted · Custom Printer and dual extrusion
First of all thanks for the great software.
I have a 3D printer (hellobeeprusa) and I am trying to set it up as dual extrusion in Cura 2.4 beta.
I've created one profile based on the ultimate_dual and changed some settings according to my printer. The issues i am facing now are two:
- when i open cura the bed is not in the middle of the STL picture that i am using of the beeprusa.
but the most important:
- in the log i always get the message
WARNING - cura.Settings.ExtruderManager.getMachineExtruders [375]: Tried to get the extruder trains for machine Custom Beeprusa Dual Extrusion, which doesn't exist.
    The extruder file i did
    "id": "hellobeeprusa_dual_1st",
    "version": 2,
    "name": "Extruder 1",
    "inherits": "fdmextruder",
    "metadata": {
    "machine": "hellobeeprusa_dual",
    "position": "0"
    "overrides": {
    "extruder_nr": {
    "default_value": 0,
    "maximum_value": "1"
    "machine_nozzle_offset_x": { "default_value": 0.0 },
    "machine_nozzle_offset_y": { "default_value": 0.0 },
    "machine_extruder_start_pos_abs": { "default_value": true },
    "machine_extruder_start_pos_x": { "value": "prime_tower_position_x" },
    "machine_extruder_start_pos_y": { "value": "prime_tower_position_y" },
    "machine_extruder_end_pos_abs": { "default_value": true },
    "machine_extruder_end_pos_x": { "value": "prime_tower_position_x" },
    "machine_extruder_end_pos_y": { "value": "prime_tower_position_y" }
    and the profile
       "id": "hellobeeprusa_dual",
       "version": 2,
       "name": "Custom Beeprusa Dual Extrusion",
       "inherits": "fdmprinter",
       "metadata": {
           "visible": true,
           "author": "na",
           "manufacturer": "na",
           "category": "Other",
           "file_formats": "text/x-gcode",
           "icon": "icon_ultimaker.png",
           "platform": "hellobeeprusa_platform.stl",
           "has_materials": true,
           "machine_extruder_trains":
               "0": "hellobeeprusa_dual_1st",
               "1": "hellobeeprusa_dual_2nd"
           "first_start_actions": ["UMOUpgradeSelection", "UMOCheckup", "BedLevel"],
           "supported_actions": ["UMOUpgradeSelection", "UMOCheckup", "BedLevel", "UpgradeFirmware"]
       "overrides": {
           "machine_name": { "default_value": "Hellobeeprusa Dual" },
           "machine_width": {
               "default_value": 185
           "machine_height": {
               "default_value": 190
           "machine_depth": {
               "default_value": 200
           "machine_center_is_zero": {
               "default_value": false
           "machine_nozzle_size": {
               "default_value": 0.4
           "machine_nozzle_heat_up_speed": {
               "default_value": 2
           "machine_nozzle_cool_down_speed": {
               "default_value": 2
           "machine_use_extruder_offset_to_offset_coords": {
           "machine_gcode_flavor": {
               "default_value": "RepRap (Marlin/Sprinter)"
           "machine_start_gcode": {
               "default_value": "-- START GCODE --\nG21 ;metric values\nG90 ;absolute positioning\nM82 ;set extruder to absolute mode\nM107 ;start with the fan off\nG28 X0 Y0 ;move X/Y to min endstops\nG28 Z0 ;move Z to min endstops\nG1 Z15.0 F9000 ;move the platform down 15mm\nT1 ;Switch to the 2nd extruder\nG92 E0 ;zero the extruded length\nG1 F200 E6 ;extrude 6 mm of feed stock\nG92 E0 ;zero the extruded length again\nG1 F200 E-{switch_extruder_retraction_amount}\nT0 ;Switch to the 1st extruder\nG92 E0 ;zero the extruded length\nG1 F200 E6 ;extrude 6 mm of feed stock\nG92 E0 ;zero the extruded length again\nG1 F9000\n;Put printing message on LCD screen\nM117 Printing... ; -- end of START GCODE --"
           "machine_end_gcode": {
               "default_value": " -- END GCODE --\nM104 T0 S0 ;1st extruder heater off\nM104 T1 S0 ;2nd extruder heater off\nM140 S0 ;heated bed heater off (if you have it)\nG91 ;relative positioning\nG1 E-1 F300  ;retract the filament a bit before lifting the nozzle, to release some of the pressure\nG1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more\nG28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way\nM84 ;steppers off\nG90 ;absolute positioning; -- end of END GCODE --"
           "machine_extruder_count": {
               "default_value": 2
           "prime_tower_position_x": {
               "default_value": 195
           "prime_tower_position_y": {
               "default_value": 149
