Would you consider the 2+ old as well? In that firmware it is the same.
For a solution: yes, preheating before keeps the fan on but I wanted to see if it is worthwhile to open a github issue...
Um2+ firmware isn't much different than um2, they only added a bunch of material profiles, and they never fixed the system to update the materials or any significant change. So yeah
I think is worth, since is a bug of the way the pin is called only when heating, and not when it just heats.
Sounds like maintainance and critical bugs only :( but well I will post the issue
neotko 1,418
Interesting. That could be a bug. Afaik the pin auto tune is implemented very roughly on um2 firmware and was never changed. UM has the tendency of leaving old machines without any update for the small % of stuff that the 99% of users don't use.
You could make a trick, very easy. Preheat the hotend to 50-60C so the small fan kicks in, and then run the autorune. It shouldn't change the values much (or none at all).
