The ICE PET is more flexible than PLA, so in applications where it has to flex a bit, such as keyrings or snap-fit clips, it works better and has a longer life.
But thin plates or structures do sometimes fracture indeed. So I don't think it is stronger than PLA, only more flexible. And it is transparant, which may be usefull in some cases, for example to make watermarks, rulers or logos totally inside the model. So I use it mainly for these purposes. In other cases the transparancy may be a disadvantage.
I also printed around the same temp and speed: 25 à 30mm/s and 220 à 230°C. Printing a bit hotter and without fan improves strength, and improves transparancy, but not very much.
1
kmanstudios 1,120
I've had pretty good luck with PETG and T-Glase. Although in the same family, is it different enough to make a big difference?
