For the gray and black style heated bed cable, the thick gray wires are going to be your heater wires, and those are interchangeable with each other as long as the gray ones are both in the Heated Bed slots. The same goes for the two thin black wires; they're interchangeable as long as they're both in the temp sensor pins.
A bit offtopic. Do the new beds have solderless connections like the um3 cores?
fbrc8-erin 270
Edited by GuestLink to post
