This is the heated pcb only, you need more parts, powersupply,the actual aluminium bed, linear bearings, leveling scews,springs,glass plate, glass clips, etc
There are threads here with people doing unofficial heated bed upgrades, try search.
On another note, I have the official heated bed kit, and lot of these kits have problems, the connections on the pcb are bad and lots of people get temperature problems.
I did resolder the pcb and the connector just to have it fail again after a few weeks, I ended up doing like its done on the pcb you found on ebay, direct solder the wires to the pcb, so I would atleast recommend this heated bed pcb, the rest you need to DIY or buy more unofficial clone parts.
catohagen 41
example, the aluminium bed : http://www.robotdigg.com/product/1015/UM2-aluminum-machined-base-plate
