Oh wow, I had no idea.
Yeah, adding 5 C by default to the starting temperature is just ludicrous. Why 5 C? What about different materials? What about different build surfaces? What about the fact that people have already tweaked their settings and arrived at settings and profiles and whatnot that work for them? And then the new Cura version steps in and makes a decision for them and changes things up.
Wow. If this is in any way a democracy, then I vote NO. Don't ever, EVER change my settings by default with a new version of the program. Just don't do it. If you want to give me new options that's great. But don't change my settings by default with a new added feature. That's completely bogus.
ahoeben 1,657
There's a new setting in Cura 2.4 to allow you to set the nozzle temperature for the first layer. By default this is set to the normal nozzle temperature + 5.
On a personal note: this is exactly why I argued that this should not be the default, even if the +5 degrees for the first layer may give better result for some (most?) materials. I feel your confusion.
