David here, "master of disaster" so to say, as I'm in the lead of firmware development.
1) You need to confirm the printer is empty after a print, so we know it is possible to start the next print remotely. You should be doing this when you are taking the print out of the printer, so you are at the printer and visually you can see that is empty. (Note that everyone else with network printing does no checks at all, or needs a on-printer confirmation before starting a print)
We did identify that the current flow isn't optimal in two cases:
a) If you abort a print before anything is printed the bed is still empty, so no need to ask the user.
b) If you remove the print before everything is cooled down, you do not get the option to mark the printer as emptied yet, as the printer is still "finishing up"
2) This feature didn't make the initial release due to time constrains. It is in testing right now, so it will be available shortly.
3) Not sure what you mean? "reconice" isn't available in my dictionary.
4) Single extrusion prints? Because of a bug. We heat up the printcores to their starting temperature. However, with a single extrusion print, the 2nd core's starting temperature is "0". And we heated up to "melting" temperature for active leveling. So it is waiting for it t cool down after active leveling, as it is going to the starting temperature.
(Currently in development, almost fixed)
And respectfully. You do not know it better because you have an UM2. The UM2 is a much much simpler machine. Networking, nozzle lifting and PrintCores change everything.
Daid 304
Hi David,
nallath 1,117
Also, if you want less checks, put the machine in developer mode (with all risks that implies).
