BenBurger 0 Posted February 9, 2017 in Unable to print first time user (edited) Hey everyone, I just purchased an Ultimaker 2+ extended and trying to get it up and running for its first print. I walked through the installation steps, but ran into a problem. I loaded the filament material into the feeder, which advanced the filament through the tube to the nozzle. However, when I get to the part where I need to wait for the material to come out of the nozzle it never does. I let it run for about 30 minutes, and then selected cancel. The nozzle is new, and hot. But it does not seem to advance the plastic out the end. Since this is a new machine, I don't think it is a clog, and the filament is drawn all the way to the nozzle, and I can see the feeder rotating. Any suggestions for getting this printer working? I read about the atomic method on the webpage, should I try that? Any help is greatly appreciated.... Edited February 9, 2017 by Guest Share this post Link to post Share on other sites
BenBurger 0 Posted February 9, 2017 in Unable to print first time user I reloaded the filament, and noticed that the feeder had dug into the filament, which prevented it from feeding into the nozzle. I reloaded the filament, and pushed it until it begin to feed into the heated nozzle, and then it started to pour out. So try removing the filament and restarting.. and look for that dug in filament point in the feed. It works now! Share this post Link to post Share on other sites
SandervG 950 Posted February 10, 2017 in Unable to print first time user Hi @Benburger, thank you for your post and welcome to the forums! Good to read your Ultimaker 2 Extended+ works By turning the set screw on the top of your feeder you can change the tension on the spring in the feeder. Since it works now, and it is 'out of the box' it should be fine, but it is something you can look at for future references. Somewhere around the middle should be fine. Alternatively, maybe there was something else near the printhead, that obstructed the filament from moving further (could be a clog or an unwanted edge somewhere) and that prevented it from extruding. Was the tip of the filament you are feeding a clean cut, and are there no edges to get caught somewhere? It is advised to make sure the tip is straight and pointy. Good luck, and curious to see what you will be making! If you want, feel free to share it with us in our 3D Print section Share this post Link to post Share on other sites
