Posted
(edited)
· How to control the LED-PWM Outlet at UO+
You should use @amedee firmware for that, it adds led control on the panel control and it even saves the brightness so when you turn it on it lights on like a um2.
one question still: When I start the firmware-builder and choose the Ultimaker Original+ printer, I get a lot of alternatives to change in the lines below, but I can't find an LED option to choose!
Is the LED-option built into the generator as standard?
Uwe
Indeed. If you just choose umo+ without changing anything you get an standard umo+ firmware, but with added Led pwm control
I finally took a different path though. As my LED-stripes turned out to be 12V, I had to use some hardware (LM7812) to adapt it anyway. So I connected it to VCC2 (+24V) at Pin1/J15 (PWM/LED) and to GND /-24V at Pin3/J9. Both pins were unused at my board and easy to access. I use a little switch to control the lights.
neotko 1,417
https://ultimaker.com/en/resources/20983-ultimaker-original-custom-firmware-builder
Like this:
basteluwe 1
Thanks for that,
Uwe
neotko 1,417
Thanks for that,
Uwe
amedee 349
Yes indeed there are very few things you can't opt-out, mostly bug fixes. Led control is one of them.
I should probably document that as I tend to claim that without any option it is the same as the official firmware, but it is not 100% true anymore.
neotko 1,417
Indeed. Is better.
basteluwe 1
Thanks for clarifying that.
Have a nice sunday,
Uwe
