It's very difficult to tell anything from your picture because we don't know what we are looking at. Maybe you could add a few info:
1/ What material were you using? At what temperature? What brand?
2/ Did you level the bed?
3/ Can you give us your print set-up.
4/ Since you bought this machine used, did you make sure you have the latest firmware update?
5/ Inspect the printer and make sure that all the screws are tight, especially the one holding the stepper motors. Lubricate the machine with oil, sewing machine oil works very well.
6/ You need to make a test. print circles, maybe 2 mm high and 50mm diameter?, print one in the middle and 1 on each corners. take a picture and post it.
darkdvd 997
A ce point, non, c'est pas fréquent.
Regarde ça : http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#circles
Edited by GuestLink to post
