Ultimaker3 web interface problem at initial setup (naming the device)
Nazdravi
Posted · Ultimaker3 web interface problem at initial setup (naming the device)
Ultimaker3 is connected with LAN cable. When connecting to the web interface this provides only "WiFi initial setup". If this is chosen first step is to name the device. Whatever is given as device name is rejected for the reason "only ASCII letters, digits and "-" are valid characters". I tried "LW", "Ultimaker", "LW-Ultimaker". All these names do match the given criteria but all are rejected. The printers firmware is the latest stable by today.
Any ideas on this?
Thanks + regards
Nazdravi
    Firefox? Pragmatic solution: try a different browser...
    (or temporary allow scripting, cookies,... whatever...)
    Thanks for answering. Yes, first try was with Firefox. But same problem with Konqueror (KDEs browser). Such simple task (fillin and processing of a form field) should succeed with any browser.
    Thanks + regards
    Nazdravi
    The WiFi setup is designed to be only used during the WiFi setup. If used at any other time, it bugs out and shows this incorrect error message.
    We are planning towards a proper website dashboard for the printer.
    Does this mean that the devices web server has no other function than WiFi setup (and this fails)? My printer is in a state where WiFi setup launches automatically (as index page).
