Thx, I always thought the line width had to be the same size as my nozzle (which is 0.4mm). Cura shows wall width and infill width, I will test them out. Seems like maybe increasing infill width might hopefully do it.
Labern 774
You could try changing the line width ( or nozzle diameter )
A 0.4mm nozzle can print lines larger than 0.4mm and smaller eg 0.3mm
Don't adjust the flow as it doesn't adjust the spacing between the lines but manipulating the nozzle size in Cura does.
Edited by GuestLink to post
