if your model is all good then you don't need any. Sometimes they can prevent things that you want.
If layer view shows everything is ok then you don't need to turn them off.
So did you make changes to correct any issues or does it look fine in layer view but your prints are not good?
Labern 772
Make sure you check layer view first before any print so you can detect some of these problems. You can even go into CURA setings and have it show one layer at a time to see the missing outer walls.
Look at this after every change you make to try and resolve it. I normally leave it in layer view in the problem area and make changes till you see its corrected.
I would first check Xray mode to see if any errors in the model and rule that out as an issue.
You may need to turn off all of the mesh fix options if your model looks good.
The retract count thing can be a double edge sword. You can have heaps and heaps of retractions without grinding if the speed is low.
but to remove the vertical string your getting you need the retractions fast. I had same issue recently and set it to 45mm/s
Cura 2.4 has Z-hop set quite high which is good for some things but i think you can get away with 0.4 or even turn it off.
To also reduce stringing you may need to drop your temp 5 to 10 deg.
Enabling coasting is also another method but not something i presonall have experimented with.
Rossboss 0
So I have thoroughly gone through the X-ray and layer view (single layer at a time) and have seen absolutely no gaps in the layers or other errors. You said you recommend disabling all mesh fix options? Even the ones that seem irrelevant to this scenario?
Edited by GuestLink to post
