Thank you for your warm welcome!
Yes, that is exactly what I have in mind. Similar to "y-mixer" setup from Prusa (and many others out there).
I noticed the foehnsturm project, I wish I could be a beta tester. It looks very promising already.
Since you have been experimenting with dual extrusion yourself, would you be able to address the question about the thermistor? Will the firmware trigger a safety when for instance the second thermistor detects a rising temperature when the second heater cartridge is switched off?
I want to make sure what I have in mind will work before I start buying extra parts for this project.
What other project (the one that's not in English) are you referring to? Crema's water cooled setup?
Best regards,
Chris
krys 206
Hi there,
Welcome to the forums!
I have not seen anyone talking on the forums about a UM2 single hot-end dual setup like what the Cyclops or what Mr. Prusa is doing. Maybe you are the first!
But there are a couple UM2 dual print projects going on right now using different techniques.
You might want to check out @foehnsturm's project here, for example.
(Disclaimer: I am part of the beta test for the above project.)
I am not sure about the other project (as it is not being coordinated in English so I cannot read it
), but I hear it is working too.
Or, maybe you want create the single nozzle version and then UM2 can have even more options!
In which case, good luck!
Anyway, hope this helps.
