This is only happening when WiFi printing?
Is cura running&monitoring the printer when this happens?
Does the menu on the printer still respond?
If the menu responds, what happens if you try to tune the temperature?
Can you send me the log files after this happened? Instructions:
- Wait for the problem to happen
- Restart the printer
- Insert an USB drive
- Goto the maintenance->diagonstics menu, select "dump logs to USB"
- It will create a file on the USB drive, send me a copy
1
esteban-pacheco 33
already did it... it works soemtimes, sometimes int freezes, it is random
