yellowshark 153
Yup I have been caught out by that too, assuming it is saving .stl files. IMHO it makes more sense to default to .stl file type. I will change settings a number of times and when I am happy then save the project.
nallath 1,080
It is intended behavior, but one that will change. We just had a discussion about this last week.
The proposed solution is that the buttons on the lower right corner will "pre-select" the preferred file type of a printer (*.gcode in 99% of the cases). The save / save as button will have project as a default.
jonatanrullman 17
Excellent. Now that I am aware of it I won't be fooled again of course, but it was kind of irritating having to reslice six models and save again as I hadn't even reflected that the save button could do anything else than gcode. I almost exclusively save straight to SD card so I hadn't looked closely at the save dialog that opened in this case. :-)
Sounds like a reasonable solution. Having a predefined primary mode and a drop down integrated into the button where you can quickly save as one of the other might be a good feature as well if there are users who regularly save in more than one format. Personally I will only use either gcode or save project for the foreseeable future.
Cheers
