Yet another non-sticking printer
zippy
Posted (edited) · Yet another non-sticking printer
It seems like hair spray is the be-all-end-all if you continue to have problems with not sticking after other methods, so I'm sure I'm doing something dumb yet I cannot get a print started now that will stick.
With a glass bed, printing a model that's about 7" wide on the 8" bed, I've tried:
glue stick
plain Elmer's glue spread out thin
small/light amount of hair spray
soaking the damn thing in hair spray
using levels to verify level bed
re-distancing bed/extruder numerous times to .2mm (1.75mm filament, 0.4mm extruder)
different bed temps and materials
That large piece went from one entire quarter peeling up by the 4th layer, to now I can't lay a single bead to start because the line rolls itself up, or if it does stick in an area initially it is pulled off line by the continued bead.
I'm really thinking it shouldn't be this hard. The light coat of hair spray (Aquanet Extra Hold) or glue doesn't feel sticky at all to touch when it dries even with heated glass. It acts like the bead is sticking to the extruder? I try to scrape the extra filament off the nozzle before each attempt to reduce that, doesn't help. I was hoping before I continue down the path of painter's tape, wood glue, salt or suger water, etc. someone might see a glaring mistake I'm making. Needless to say, probably, new to printing, only 2 small model success so far, then tried this 7x-failure with a large model. Thanks for any help.
    Posted · Yet another non-sticking printer
    Almost certainly your nozzle and bed are too far abpart. I don't care what the calibration routine is - you are ending up with the bed and nozzle too far apart on the bottom layer. What kind of printer is this?
    "... That large piece went from one entire quarter peeling up by the 4th layer, to now I can't lay a single bead to start because the line rolls itself up, or if it does stick in an area initially it is pulled off line by the continued bead....
    Yup @gr5 is absolutely right. Your lines of filament need to be "flat" not "round". If you find your walls on the 1st layer are sticking well but the infill is not sticking then you have gone to far, back it off a little - .050mm can make a huge difference
