As a very off-topic side-note: Ultimaker2 Mark2... The name is a bit of a missed opportunity, because it does not say anything about being dual extrusion.
Why not do something clever, and add a "D" for dual to the name. So... Ultimaker 2D!
(I suggested the same postfix during the development of the Ultimaker 3, but strangely "Ultimaker 3D" did not get much traction.)
ahoeben 1,654
> So I would like the settings to be just always available, but if for some reason this would be to complicated,
Unfortunately, it is fairly complicated in the current architecture. I would have liked to be able to do this too, but I don't think it is going to happen any time soon.
> it would already be an improvement to keep showing the button "greyed out" with a warning on hover, like "machine not active"
How would this be an improvement? Functionally this is still the same as the current solution; you still cannot enter the machine settings. And technically, this is still fairly complicated to implement.
Cura basically only knows about one configured printer at a time (and a list of other configured printers as id and name, but not much other info). The available "machine actions" (Machine Settings, Upgrade Firmware, Bed Leveling, Connect to Network, etc) can vary between printers. And these "machine actions" are all fairly hardcoded to work on the currently active printer.
