so i changed that value to 60 and uploaded the firmware directly from the arduino IDE and nothing changed, it is still capped at 20. I could not find any other value in the configuration.h file that could possibly change this
That's the only change they made regarding this. Did you do a factory reset after the change you made?
no i uploaded the firmware, the printer restarted, then i went and checked the retraction settings and they hadnt changed
Some changes only take effect after factory reset. So I would try that first.
Labern 772
This is the change that E3D put in the firmware. The 20 is for the extruder (x,y,z,e). Should be in the configuration.h file
DEFAULT_MAX_FEEDRATE {300, 300, 40, 20} // (mm/sec)
