kmanstudios 1,117
I have taken to exporting my material and print profiles via the configuration tab to create non-installation required backups. That way I can blow out the folder setup that Cura references and still reload (manually) the profiles.
However, Having the same OS would probably be required unless the data is stored in a form that is transportable (ASCII, etc).
SandervG 1,505
Do both laptops run on the same OS? If so, I think it should work. Otherwise, I think not. But perhaps @Nallath could confirm or correct me.
