Labern 774
Take the glass off the printer and use a straight edge or steel rule to check to see if the glass is flat.
There has been issues with bent glass beds and i suspect this to be an issue in your case.
If it is bent then contact your reseller.
You should only need to re-level your bed once every month with PLA unless you print with other more tricky materials.
