Let's reanimate this short thread!
@ahoeben This is what *I* did: load a STL, tweak some settings like 44% infill to get a very odd and individual profile, save all as curaproject (and cura is detecting, I made 2 or 3 changes in the profiles). Then I change material and profile, delete the old STL and open the *.curaproject.3mf
The attached file should be in PLA, with 44% infill and 69mm/s print speed. When I open it in Cura 3.2, none of the settings reappear. Only geometry and the recent profile/material.
@mattgriffin You said in your "Went ahead and bought the UM3X"-Post
On 18.2.2018 at 4:48 PM, mattgriffin said:1) save cura project files and date stamp them each time you print. Sure, you just need the gcode to print with, but that project file HAS all the settings in there, and you can even duplicate one, kill the mesh part currently loaded, and apply favorite settings to the new job
But this was not possible for me. How does this work?
Cheers,
dxp
Edited by dxp
deleted attachment - for security
ahoeben 1,717
It does save the settings in the cura project file. How do you load the project back in? You have to use the "Open Project" menu, or else the project is loaded as a model, without settings
