Umm @catohagen next time you buy, drop me a PM I know a couple of shops that deliver close to almost ok stuff.
First things first. The one you bough doesn't have an olsson, it has the old old um2 hotend without swapable nozzles. VERY expensive for that. Basically you will get Aluminium parts (retail price from UM reseller is 30-40€). Plastic parts, can be printed on a Greentec, but that should work. Ptfe coupler (the old one! 50-200h print time max) and the spring, that in my experience clones use to sell a very bad spring that can get flex when retracts or do too much force bending the tip of the coupler.
The screws, are too long, way too long. And doesn't have fan-fancap? You will need to 'cut' the long screws in order to install most fan caps.
Next time really drop me a PM. I been-there-done-that for 2 printers.
As @amedee says you can use the thermocupler since is 3.00mm so, should fit on an olsson.
The cheapest route IMO is. Get aluminium parts from a UM reseller, this is the most important part of the hotend. The plastic parts can be printed with a 100+ heat resistant material like greentec.
Omg you also need the 5V fan!
Ok... Alu parts of UM, 30-40€, olsson depends from 30 to 60€ a real one. I seen olssons for 4€ that might be horrible, but I have 2 china olssons on a box for a rainy day that actually work after cleaning the threads (they do machine the clones a bit horrible). The most useless part from clones is the nozzle, from the outside they might look ok but the nozzle interior is really horrible drill and will clog (it really will) really fast, because they use a flat drip to do the inner, so filament deposits there and burns overtime.
So you need
- Alu parts (UM reseller is the best route for this)
- Printed top parts
- 5V Fan (reseller also is nice, but you will need to make the cable longer and solder stuff)
- Fancap (for that I would just use the @gudo fancap that uses the same fans that UM uses on UM3)
- Pt100, optional, for umo should work the thermocuple as @amedee says, and you can modify the top plastic part to install it there.
- For olsson. China clone could work, but you will need to clean the threads and make sure they didn't left a hole on the nozzle interior or a leak could flood the pt100/heater cavities. 3dsolex has a olsson for 69€ discounted price atm.
Oh Heater, you need a heater, olsson/um2 uses a 4mm heater, cheapest and safest route is to get one at 3dsolex (they do have a very good price for heaters, and trust me I have used a few china heaters and I really don't recommend that at all)
I'm missing something?
2
Top Posters In This Topic
14
11
11
11
Popular Days
Jul 3
12
Jul 4
10
Jul 5
10
Mar 27
9
amedee 14 posts
catohagen 11 posts
greengecko 11 posts
neotko 11 posts
Popular Days
Jul 3 2017
Jul 4 2017
Jul 5 2017
Mar 27 2017
Popular Posts
amedee
For the PT100 it is easy, you have all you need on the board temp pins, and no pull-up needed. See this picture: (Be careful, this is an old 1.5.3 board, on the 1.5.7 Sig and Gnd are swapped)
Posted Images
amedee 349
If you have an UMO (not +), you will need the E3D board if you want to use a PT100.
Alternatively if it fits you can still use the thermocouple, it is pretty accurate; the only downside is that you need to keep the amplifier close to the head.
For the other questions, @neotko is best placed to answer
catohagen 41
Thanks amedee, yes its a UMO (not +)
I'll go for the PT100 then with the amp board.
The thermocouple have been inserted and removed so many times, I'm surprised it still works, I'll keep it in the block as a reserve part
Then I guess its just loading up your firmware builder and readjust for PT100.
For heater, as I have the UMO and heated bed upgrade, can I use 40W heater ?
I havent looked up what wattage the orginal heater is..
