ABS is quite a bit more difficult to print and it's probably going to be much weaker than PLA. Also white PLA is the hardest color to print because I think of all the talc added maybe? So I assume white ABS is the hardest of ABS filament - but I never tried white ABS.
Does this need to withstand a lot of heat? Is it going to be in a car or something?
In general to increase quality lower speed. I would increase layer height to 0.1mm and cut the speed down to 25mm/sec. Heat/fan control is critical to get extra good quality but too much fan and you get incredibly weak ABS parts. Yet with PLA it's so simple - just put fan at 100% and you get very strong parts and very beautiful.
What was your fan speed for this? And can you use PLA instead?
Hi gr5,
Thanks for the reply. The design will need to withstand some heat, so that is why I chose ABS. The current fan speed setting is at default (regular 20%, maximum 100%), the print speed 45 mm/s, travel speed 120 mm/s, retraction enable.
gr5 2,331
Edited by GuestLink to post
