Just one question...
Try this please
a) Do an atomic pull
b) Remove the nozzle (for this is a good idea to heat to 150C at least)
c) Wait the hotend cool down to at least 35C
d) Get a piece of filament and insert it from bellow (from the opening left by the nozzle). Does the filament pass ok? Does it has some point of friction? Ofc try to straighten the filament peace so the curvature doesn't add friction.
If so, maybe when you installed the coupler the tip, due pressure, deformed.
Other question. You installed a 'high temp PTFE'. I suppose you bough a TF2K from 3dsolex that is a TFM coupler + I2K, right?
If so, is very important (IMO) to use a fixed size spacer to replace the spring of the um2. If you already did that, nevermind, but if you didn't, download and print a fixed size spacer. There are various models for I2K and non I2K users.
https://www.youmagine.com/designs/um2-spring-replacement-for-i2k'>https://www.youmagine.com/designs/um2-spring-replacement-for-i2k'>https://www.youmagine.com/designs/um2-spring-replacement-for-i2k'>https://www.youmagine.com/designs/um2-spring-replacement-for-i2k
https://www.youmagine.com/designs/ultimaker-2-spring-replacement
https://www.youmagine.com/designs/um2-adjustable-spring-replacement
stu_le_brew 40
have you tried adjusting the tension on the extruder, looking at the list of things above I am sure you have
