Fiber glass bed to replace heated bed for ABS printing
Posted
· Fiber glass bed to replace heated bed for ABS printing
there are a number of printers that use fiberglass (PCBs) as printing surface. It doesn't eliminate the physical shrinkage of ABS, and the resulting delamitation forces, with easily warp even standard 1.6mm boards, while the ABS is attached to it. it may get better when you use 2-3mm boards, but then it becomes a struggle to remove the print from the board as well (unless you use a pegboard with pins to push off your print)
joergen 2
