Posted · how to connect Prusa Alit A8 i3 to Cura 2.3.1
I am trying to connect Prusa Alit A8 i3 to Cura 2.3.1
I down graded one pc to win 8.1 64bit, I Installed Cura 14.07 as instructed in the manual executed the configuration file for Curra 14.07 and in the configuration menu in the printer display I stored and loaded EEprom. In the Machin setting I assigned 115200 to bud rate and com 3 to the serial port.
My PC has 3.0 USB ports.
Connection was made and I confirmed that I can print using the USB connection from Cura 14.07 on my PC to the Alet A8 i3.
I installed Cura 2.3.1 and found out that I have no way to define port or bud rate or any way to connect to the printer
need help, I don't now where to start
thanks
Dov
