Upgade to 2+
Big_G
Posted · Upgade to 2+
Hi and welcome,
I don't think so, please check that the switches are still activated when moving the head by hand. They are activated by the rods, so maybe you didn't put the rods back in place.
If you have an error message (X/y switch broken) then usually a factory reset helps (be aware that you should remove the filament (maybe by hand) because the wizard will go through the first run thing
    Posted (edited) · Upgade to 2+
    Hi and welcome,
    I can not do a reset as it is locked into the first start wizard and won't allow me anything other than work through the wizard until  it hits the ER07 error. How can I skip the wizard and do the factory reset?
    Hi and welcome,
    Thank you for the suggestions but I solved the problem. The X-Axis switch was not fully activated due to the fan ducting on the print head was wider than the original and was fouling on the printer casing not allowing the limit to fully trip. I repositioned the switch so it tripped before the print head contacted the case.
    PROBLEM SOLVED!
        • 4 replies
