Very strange. I tried the same part on a clean install of Cura 2.5, with the same results. I also noted that if you just translate the part over the virtual table, the supports change shape.
I am a bit hesitant to click on non-descriptive short links like these. In this case they may be honest and harmless, but I can not differentiate such links from spam or viruses (like in malicious e-mail links). More and more spam is now custom-made and thus getting harder to recognise, both in mails and on forums. So I am not going to take the risk.
I would suggest that you upload pictures to the forum, so that we can always see them immediately, without need to download anything; and that you use long and descriptive links to an HTML-webpage for any downloads, but not directly to the files, and no short links.
This still doesn't guarantee safety, but the risk is lower.
Inline, as requested.
STL file:
I get much the same result when using 2.5 Final. I have 2.5 Final on a different computer than my actual work station on which I keep 2.4 Final. The reason I keep it on a separate computer is because I too have found some anomalies in the way Cura 2.5 Final, with multi threading, handles support structures.
Suggest if you really need to print this file you bring it into 2.4 Final, if possible on a separate machine.
Just my 2¢ worth . . .
XYZDesignPro 70
Must be something at your end. Part looks fine in Cura 2.4 using default (Recommended) settings.
