Hi gr5,
Thanks for the answer!
Either rerun the calibration procedure and do it manually and make sure the two nozzle are exactly the same height.
So far I've rerun the calibration procedure several times with no success. I do not understand why when I use the calibration card, I get the needed resistance when sliding under the BB print core but when I start the calibration procedure it just does not apply the material on the glass. At the end It seems that the BB core is not close enough to the glass.
At which point should I try this? Or just raise the platform and do it?So option 2 is to raise the bed just a little bit by turning the 3 screws counter clockwise about a half turn to get the filaments (both pla and pva) to squish a little better into the glass.
Is there some tutorial/video for applying the glue?Use the supplied glue stick and put down just a small amount (back and forth maybe 4 times with the stick with most glass getting nothing) then spread it around with a wet paper tissue.
gr5 2,330
PVA is trickier to work with than PLA. The basic problem here is that the second nozzle is too far from the bed. Either rerun the calibration procedure and do it manually and make sure the two nozzle are exactly the same height.
Or maybe they are the same height and you just don't notice it so much with the PLA. So option 2 is to raise the bed just a little bit by turning the 3 screws counter clockwise about a half turn to get the filaments (both pla and pva) to squish a little better into the glass. They should be flattened like a pancake.
Squish is the main problem but it also helps to put down a layer of PVA glue. Use the supplied glue stick and put down just a small amount (back and forth maybe 4 times with the stick with most glass getting nothing) then spread it around with a wet paper tissue. This wet tissue will help make it very very thin and also remove some pva which is good. Heat the bed to 60C until it's dry (just a few minutes).
