Hi! I just modeled a simple plate with
W = 13.5 mm , L = 75mm , Hc ~2mm
Wc = 0.4mm and Ww = 0.2mm in the model I loaded in Cura.
It looks like Wc is slightly bigger and Ww is slightly smaller in the actual printed model, which is visible in the pictures below. But there is a gap between the lines, and this was printed with the PLA normal profile, no changes.
DidierKlein 729
Hi and welcome to the community!
Can you share maybe a picture of how it looks like?
0.1mm is quite small so it has to be quite fine tuned i guess. I would probably try to print as cold as possible and slow to (20mm/s - 30mm/s).
I don't really know what micro channels are but i guess it's some empty cylinders of 0.1mm?
Edited by GuestLink to post
TazFaunoz 0
Hi dude!
Thanks for the answer.
Yea maybe 0,1 is too small. I've seen on the literature thta the channles's width is about 200-400 micron.
What do you mean when u say "cold as possible"?
And what about the others parameters?
This is the image.
