Something wrong during slicing...
makingzone
Posted · Something wrong during slicing...
I've got trouble to slice this 2 parts design with solidworks then export to STL...
This 2 parts is an assembling of 3 parts, and the 3rd (the biggest) was slice and print without trouble...
Do you think the clips are the cause of the issue ?
Part1
Part2
    Hi Elbozo
    They slice up in Netfabb no problem once it was oriented to sit on it's back on the platform.
    The clips won't print great without support due to the 90 degree overhang.
    There is the end of the log file :
    self.svgElement.getFirstChildByLocalName('title').setTextContent(os.path.basename(fileName).decode("utf-8").encode('ascii', 'replace') + ' - Slice Layers')
    UnicodeEncodeError: 'ascii' codec can't encode character u'\u0301' in position 14: ordinal not in range(128)
    It's another one of those damn ascii encoding bugs. I've fixed it for the 13.04 release (will be out soon to get rid of some small bugs)
    Most likely your filename or path contains an "odd" character. (anything not a to z)
    Ok Daid, Thanks for informations. I'will try to rename and deplace the file, and if the problem isn't solve, wait until the 13.04 release.
        • 9 replies
