1st layer width settings in Cura 2.5
porlock
Posted · 1st layer width settings in Cura 2.5
I use an old Cura 14.x and there was a setting called initial layer width, it was available in advanced tab, Now i change my soft to Cura 2.5 and i cant find it. I see setting to change width of top/bottom layers at the same time, but i do not want top layer wider. I used this setting better bed adhesion, last layer have pretty good stick and does not need to be wider.
    Posted (edited) · 1st layer width settings in Cura 2.5
    Really nobody knows how to solve my issue :(?
    • Is they a way to set 1st layer width in Cura 2.5 ?
    • Why this new top/bottom layers width is made for ?
    • Or why 1st layer width was deprecated ?
