Ultimaker Community of 3D Printing Experts
A better Bed Glass - Neoceram Glass
  • Replies 80
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
I been testing for almost two months a different bed glass called Neoceram as an alternative to the UM bed glass, so here they some my impressions and 'why'. Neoceram is a Ceramic infused glass made
Posted Images
Posted · A better Bed Glass - Neoceram Glass
I must admit that all my attempts to find a suitable glass locally failed, too. The ones from Spain asked absolutely unreal price.
So, if anyone has a suggestion for a supplier in Europe - all kudos due.
    Posted (edited) · A better Bed Glass - Neoceram Glass
    After the Neo-Sanding, we have de Neo-Ceram...
    Neoceram is a product of a Belgian company: Haerens. They are manufacturing in Belgium and Spain.
    I just found in Belgium VitreFlam which sells these locally for about 50 € tax & shipping included. They have International sites in some European countries, US and Canada.
    (I don't know  them, never ordered there -- this is just FYI)
    • Like 3
    I actually found a place where I can order them online here in Denmark, but not sure if its the right stuff yet (its cheaper than what I have to pay for the original glass here)
    Also.. I found a certain aliexpress store that sells ceramic glass for um2, I wonder if they are reading this forum, maybe neotko is running it ;)
    I can promise you that I make zero money sharing my stuff and posting here.
    Post a link? Well maybe if they read the forum they will make better than bad clones someday.
    Edit. Oh I see is the Jennyprinter clones
    In my experience their stuff is crap and beyond. Maybe they are doing better stuff now, but I doubt it.
    I was only joking of course :)
    I have no idea about the quality, just thought it was interesting that they had it.
    Also they are not really cheaper there.
    Received my "glass", looks very good. First print looks fine, no issues so far.
    Cost 40€ including shipping.
    One thing the website doesn't say is that the back has a fine grid texture.
    Cold you make a picture of that?
    is it sanded or what is it like?
    If it was sanded - wouldn't this result in an feature like a buildtak mounted?
    Ahh, I found that site before...one of the foreign ones...never realized that they had "local" sites. Thanks! :)
    Here is a picture. It shows a close up with a nickel on the glass to help you understand the scale. The surface is smooth-textured as you can see. I don't know anything about buildtak.
    Aoh!
    This is rally rough. A buikdtak is more like 200grain sandpaper.
    Thanks for the picture!!!
    Wow that’s like a kitchen ceramic glass? Mine is invisible to the naked eye.
    My glass vary beetwin 3.98 to 3.85mm... most of the time it works fine but I would like to get a replacement one and maybe try a hardcore cooling with those ceramic glass.
    I found a local SCHOTT reseler but they don't have the ROBAX, only NEXTREMA glass-ceramic that also looks great! Anyone have tryed this one?  It's cheaper than Borosilicate glass, converting to US dolars it's 20 bucks.
    Tolerance looks the same as related on specs:
    Thickness t = 4.0mm
    Tolerance ± 0.2 mm
    An importante spec is not listed, Flatness along the diagonal. I sended an e-mail to ask about it for 4mm thickness.
    Nextrema specs and promotional video
    It has 6 colour, the blue gray and opaque grey looks great! Properties vary a little beetwin those. The reseller only have the transparent one. :(
    glass colours
    Cool @fergazz I hope they gice you more feedback. Also neoceram is cheaper than the um glass. And super flat
    OMG, opaque white also looks great for Ultimaker enviroment :p
    Schott Brazil replied my e-mail with some informations.
    Comparision of coefficient of expansion:
    Tempered: 6.0x10^-6
    Borosilicate: 3,3x10^-6
    Neoceram: 0.6x10^-6 (close to zero)
    Thermal shock:
    Tempered: 270°C
    Borosilicate: 360°C
    Neoceram: 760°C
    edit: The color variation in Robax and Nextrema are related to the transmission of UV and IR radiation, due to the oxides that compose the glass ceramic, but this does not interfere in the performance of the product nor in the heat transfer
    They also told me that glass is monolithic and does not suffer delamination because it is a single block, but I think this does not refer only to the Nextrema or Robax, the borosilicate also, I was in doubt if the temperate is monolithic too, it was not clear .
    About diagonal flatness they have not answered me yet.
    Which glass comes in UM2? Is it temperate, borosilicate or other?
    Tempered glass afaik
    Thickness t = 4.0mm
    Tolerance ± 0.2 mm
    give me the contact of the dealer.
    @fergazz
    According to this pdf page 34 http://www.ferret.com.au/ODIN/PDF/Showcases/106092.pdf
    the flatness along the diagonal D flatness.thumb.png.8ff57aa37f6ab287bef57a76d631d640.png
    Sure @lordhell, (are you Eduardo?)
    VIDRAK VISORES DE VIDRO INDUSTRIAIS
    email: vendas@vidrak.com.br
    I order one Nextrema last week, it's camming :)
    Looks like Nextrema is more quimical resistence them Robax, but I don't know if we have some advantage for this. It can handle up to 950°C thermal resistence and shock resistance of 700-820°C. Nextrema transparency also alows for some inovating infrared heating functionalities :D
    Schott Brazil tell me that they import a full-size glass, so they can't garantee this 0.3% of diagonal (for under 300mm size) because the glass plate is much bigger and can be cutted on diferent areas (?). But It should be much better than others glasses as mentioned here.
    That’s the kind of high precision glass Misumi sells for ALOT of $. Was one of my first choices but also thought that was a bit expensive. If has good/normal adhesion please tell/share your findings. How much they charged you for it?
    For reference misumi glass
    https://us.misumi-ec.com/pdf/fa/2012/p2_0927.pdf
    It was R$ 77 reais (U$ 23,50 or E$ 20,10 Euros) cutted with c-shape grind profile and 5mm radius on corners. The problem was shipping condition/cost, half of the glass price.
    Sure @neotko I will keep them informed about my tests. Oh yeah, Misumi is always a reference of high quality stuffs... I even didn't know that they produce glass. Cool!
    well I went for it.
    going to see how it goes. bought two for £54,- including postage :)
    looking good so far. the glass is pretty flat so I have high hopes for it.
    • 18 Visiting our virtual showroom
      1. 1. Have you visited our virtual showroom before?
        • Yes
        • No
      2. 2. If yes - what content did you find most interesting?
        • Information about Ultimaker ecosystem
        • Applications & application stories
        • Customer success stories
        • Webinar sessions
        • Material wall & ecosystem partners
        • New product introduction; software subscription plans
      3. 3. What of the below would make you consider visiting (again)?
        • New Live Ultimaker Webinar streams
        • ‘Ask Me Anything’ with industry experts or Ultimaker staff via main stage and public chat
        • New customer success stories
        • New applications
        • Presentations/news from ecosystem partners
        • Opportunity to meet representatives for an interactive tour
        • Helpful videos like Software tutorials
        • Other; leave input in a comment below!
      • Ultimaker turns 10: A look back
        Ultimaker is turning 10 years old and that means it is story telling time! We'll explore 2010-2014, traveling through the evolution of the business from the Protobox and Ultimaker Original, to the major leaps forward with the Ultimaker 2 and Ultimaker 3.
      • Ultimaker Transformation Summit
        Visit our virtual showroom and learn more about the Ultimaker ecosystem!
        • 14 replies
      • New here? Register your Ultimaker for free 3D printer onboarding course
