Posted (edited) · [solved] Cura 2.5 AppImage + Fedora 25 -> does not work
Hello,
Everything is in the title. When I start the AppImage in Fedora 25, I got the following error message:
relocation error: /lib64/libssl.so: symbol EVP_aes_128_cbc_hmac_sha256, version libcrypto.so.10 not defined in file libcrypto.so.10 with link time reference
Any idea on how to solve this?
Thanks,
K
    • 4 weeks later...
    Posted · [solved] Cura 2.5 AppImage + Fedora 25 -> does not work
    I've got the same problem trying to use the octoprint plugin on the Cura 2.6 BETA AppImage.
    cura: relocation error: /lib64/libssl.so: symbol EVP_aes_128_cbc_hmac_sha256, version libcrypto.so.10 not defined in file libcrypto.so.10 with link time reference
    I'm running Fedora 25 too. If I find a solution I'll follow up. I might file a bug too if I find the proper channel.
    Alright, I've got a workaround, at least for my problem.
    Before running the Cura AppImage, I had to preload a different ssl implementation.
    export LD_PRELOAD=/usr/lib64/libcrypto.so./Cura-2.6.0-BETA.AppImage
    Bam, Cura no longer crashes when attempting to connect to octoprint.
    • 2 weeks later...
