Make sure your Initial Layer Height is at least .5mm greater than your Layer Height.
I think Brim should be the build extruder 1, not the support extruder 2
If you have a machine available with Cura 2.4 on it try that. I've experienced anomalies with the support implementation in 2.5.
gr5 1,870
I was able to fix this but forget how. It was probably the "support x/y distance" parameter. Or maybe turn off brim.
