@RudydG can you share you latest S3D profile, I like to give it try...
I am working on a S3D profile too, I'm focusing on tool change script with idle temperature and a soft acceleration/jerk control.
The latest script is good but not yet perfect.
My current version works good. There was some ooze issues after the printer reads T0/T1 beacuse it unretract immediately the new extruder.
With regard to the expected time and the real one, the maximum incongruity was +8 minutes.
If anyone will try it, let me know if there will be some problems.
https://www.dropbox.com/s/g3bs5chtbjl1qlk/Mark2_1.1.5.fff?dl=0
Marco,
First, i did not have time to test the 1.1.5 version.
Regarding S3D and speeds / accelerations for the second head.
Did you get this to work? I see additional command in the lower script portion in S3D?
This is about the only problem i still have, getting the setiings good for my second head with different material (Ultimaker Pva)
Have a newer version to test?
Many thanks,
Rudy
Top Posters In This Topic
90
81
72
66
Popular Days
May 5
30
Mar 24
25
May 4
23
May 6
22
RudydG 90 posts
foehnsturm 81 posts
tinkergnome 72 posts
ultiarjan 66 posts
Popular Days
May 5 2017
Mar 24 2020
May 4 2017
May 6 2017
Popular Posts
rigs
@zerspaner_gerd & @MarcoUbtz Thank you gentlemen, everything is working perfectly now https://www.youmagine.com/designs/flexible-coupler-using-colorfabb-ngen-flex
zerspaner_gerd
Already found?? Here are my noted links: https://forum.simplify3d.com/viewtopic.php?f=8&t=1959
morfeushav
I am creating too a holder for mount the clamping dock on a ultimaker 2 aluminum clone. I haven´t have yet the final part., and I have to test it. This is how looks
Posted Images
chiz 20
This is the same issue I have that I refer to as below:
Issue: X rod crashes to the parked hotend (not yet solved)
I also haven't come around resolving this. Curious to know the solution as well.
