Just finished my longest print and i'm very happy to show you the ultimaker drill in 50% size:
Total print time was about 21h...The little offset at the left happened, when my prime tower lost contact with the heated bed :angry:
but all in all it came out great! My only tweak was to use a bowden tube which is slightly longer than the original one. Now it has a little bit more flexibility, because i had problems when the bowden tube pushed my second extruder to the front so it dropped off.
Next is PVA
- 3
RudydG 62
Just to let you know, in my case, it was about 5mms, and i had to change the position of the second head, i printed a plstic shim to reduce the gap to 2mms
With the 5mms my z axe went crazy during the head change or pick-up.
Edited by GuestLink to post
pixl2 33
1. Done.
2. First I changed something wrong in "Store invert flags", bad mistake:( but then I found the right menu item.
3. Have organized superglue and now it works. I still had an old unopened "Proto-pasta High Temp PLA v2.0 Iridescent Ice" spool here.
4. Done.
5. Done.
@RudydG Thank you for your feedback. I will have a look at this later (at the moment it "works" a little bit).
Fist good thing (for me), my first dual print:D:
Bad thing:
A few pages before I read something about the head2 push against the belts at the start from gcode calibration.v03 (had the same problem), so i solved the problem like an other user. I was waiting (with head2 in my hand) until the green lines (head1) was starting, then i put head2 on doking station an above you can see the result.
Bigger problem:
The printer is going out much times (heating bed, head1, head2, fan on...)
I read something about the power budget but i dont know, on what I must pay attention.
My settings (I have not made any changes):
Total: 160W
Buildplate: 150W
Extruder 1: 35W
Extruder 2: 35W
What can i do here?
