Got my Mark 2 Upgrade (with expansion board) up and running and I'm loving this thing!
Had some issues in Cura in the beginning but those cleared up after I found the updated printer def file in another tread on here, is that updated in Github yet?
Couple questions:
What are the pros and cons of running Marlin vs Ultimaker 2 gcode flavor. I have really gotten used to using the on board printer material temp setting with the Ultimaker 2 is there a reason that the definition files for the Mark 2 uses Marlin instead?
I noticed with single material prints that the second head still comes to temp, primes and sits at 175 for the entire print for no reason. Am I missing a setting or should I be slicing with the stock Ultimaker 2+ machine in Cura for single material prints?
Thanks!
Top Posters In This Topic
90
81
70
66
Popular Days
May 5
30
Mar 24
25
May 4
23
May 6
22
RudydG 90 posts
foehnsturm 81 posts
tinkergnome 70 posts
ultiarjan 66 posts
Popular Days
May 5 2017
Mar 24 2020
May 4 2017
May 6 2017
Popular Posts
rigs
@zerspaner_gerd & @MarcoUbtz Thank you gentlemen, everything is working perfectly now https://www.youmagine.com/designs/flexible-coupler-using-colorfabb-ngen-flex
qwerty8224
correct please definition of nozzles for Сura 3.4 [values] machine_nozzle_size = 0.6 machine_nozzle_tip_outer_diameter = 1.25 coasting_volume = 1.36 speed_wall = = round (speed_print * 4/3, 1)
morfeushav
I am creating too a holder for mount the clamping dock on a ultimaker 2 aluminum clone. I haven´t have yet the final part., and I have to test it. This is how looks
Posted Images
tinkergnome 852
Some steps are done by the firmware, if the print was started from the sdcard. These are usually not in the gcode.
If you add it generally, the home command (e.g.) would work, if you print via USB, but would be executed twice if you start the same gcode from sdcard.
I use this for "After print job completes" and "After print job is cancelled":
