Ultimaker Community of 3D Printing Experts
Ultimaker Mark2 - The Smart Dual-Extrusion Upgrade
Posted · Ultimaker Mark2 - The Smart Dual-Extrusion Upgrade
Ask you next I cut things out with cura Beginning of the print order is not normal Basic is running around Everything is normal with s3d Cura3.3.1 Please help resolve
    • Replies 971
    • Created
    • Last Reply
    Top Posters In This Topic
    Popular Posts
    @zerspaner_gerd & @MarcoUbtz Thank you gentlemen, everything is working perfectly now   https://www.youmagine.com/designs/flexible-coupler-using-colorfabb-ngen-flex
    Hi guys, After years of following the evolution of the mark2 project, I finally got my hands on relatively cheap second-hand Ultimaker 2 (non plus that wasn't in the best shape to be honest) and di
    Already found?? Here are my noted links:   https://forum.simplify3d.com/viewtopic.php?f=8&t=1959
    Posted Images
    Please install and use the mark-tweaks plugin, that will resolve everything ?
    where do you get the plugin from,  I have cura 3.2.0 installed along with the cura files from git hub Mark2 ?? but that plugin in is not listed in the installed plugins OR the available plugins??
    Its there with the mark2 files on github please check
    I checked my Directory Ultimaker Cura 3.2/plugins/postprocessingPlugins/scripts and it is listed Mark2Tweaks.py so I take it this is enabled automatically so you don't see it in the plugins in cura
    Nope it doesn't work like that, you gotta actually copy it into the plugins directory and then start cura and check the menu ?
    Ok Im confused hear I have a Directory called
    Program Files/Ultimaker Cura 3.2/Plugins then there's 39 Directories after that ???? none of which are called plugins ???? except PluginBrowser
    if I follow Git hub it suggests it want to be in directory cura-3.2-resources\scripts
    and under resources it has
    Definitions
    extruders
    images
    scripts
    variants
    totally confused??
    when I originally set up cura I followed the instruction on the Mark 2 web pages which I printed off last year
    scripts translates to plugins/plugins/Post processingPlugin / scripts which is where I put the file??
    That's ok. @rajilpahuja: "Mark 2 Tweaks" is a post-processing script, not a plugin.
    @bob-hepple: In Cura choose "Extensions -> Post Processing -> Modify G-Code -> Add a script"
    It should be in the list.
    • Like 2
    I had almost forgotten its post-processing, but that thing solved all my extra movement issues ?
    TinkerGnome thanks for clearing that up at one point I was about to Give up
    Done!! Thank You,  if this wasn't enabled could that have caused my heads to crash when I ran the Gcode for the calibration marks Or do I still have some setups to get right??
    Hey guys,
    I'm having a little problem causing low quality dual color prints:
    On every layer, the switched printhead always go touch the printed part first before printing the prime tower.
    This make the oozed filament stick to the print instead of the tower. Really annoying.
    It seems to be caused by the way mark2 insert the tool change code in cura. It inserts it on the last point on the last printhead pass.
    For example, in this image, after the yellow head 1 print, head 2 gets ready at the switch bay, it goes to point 1 first then goes to point 2, which leaves the oozed filament on the model.
    This issue has forced me to turn on ooze shield for dual color print. And also because of this my cura makes worse dual color print than s3d.
    I tested this on 2.7, 3.1, 3.2.
    Is anyone else having the same issue? Is it possible to improve it?
    Thanks
    The mentioned post processing script solves this.
    Thanks I didn't know that.
    I also couldn't see the script until I copied Mark2Tweaks.py to C:\Program Files\Ultimaker Cura 3.1\plugins\PostProcessingPlugin\scripts
    correct please definition of nozzles for Сura 3.4
    [values]
    machine_nozzle_size = 0.6
    machine_nozzle_tip_outer_diameter = 1.25
    coasting_volume = 1.36
    speed_wall = = round (speed_print * 4/3, 1)
    speed_wall_0 = = 1 if speed_wall <10 else (speed_wall - 10)
    speed_topbottom = = round (speed_print / 2, 1)
       then what is highlighted should be removed .... I have to Cura 3.4 works.
    • Like 3
    Posted (edited) · Ultimaker Mark2 - The Smart Dual-Extrusion Upgrade
    [values]
    Changed this on all 4 sizes and now no error message and nozzle size now shows when using Mk2 - Many thanks indeed ?
    Edited by navigator
    [values]
    I changed the file to the following to finally get rid of the error:
    Quote
    [general]
    name = 0.4 mm
    version = 4
    definition = Mark2_for_Ultimaker2
    [metadata]
    setting_version = 4
    type = variant
    hardware_type = nozzle
    [values]
    machine_nozzle_size = 0.4
    machine_nozzle_tip_outer_diameter = 1.05
    Edited by yyh1002
    Using the above fix by @yyh1002 I found you can leave the other information in place. ?
    Edited by navigator
    different screen shot & info.
    tinkergnome
    Thank you for not forgetting about this wonderful project Mark2 ....
    installed Mark2Tweaks.py (cura-3.2-resources) and my 2 nozzles became just fine to work with. Stopped to visit the place 1 nozzle all super I'm very happy)))))
    And again thanks to everyone who took part in the development of this project YOU gave us the opportunity to get acquainted with two-tone printing at minimum cost. ))))
    Edited by qwerty8224
    • Like 2
    Again broke Cura 3.4 (((.
    Printing PLA support PVA Mark2Tweaks.py does not work.
    Command Ultimaker ???
    I tried printing with the post processing script but the new head still go touch the model first. I'm using 3.4.
    I need to check this too, but it can just be that UM isnt supporting the script now, hence downgrading maybe the only option for now.
    I found that in my case the touching problem was caused by UltiGcode flavour. I switched back to Marlin and everything became perfect.
      • Ultimaker Transformation Summit
        On April 20 - April 23 we will host the Ultimaker Transformation Summit. Come talk to us via Live chat and get inspired by any of our relevant presentations!
      • New here? Register your Ultimaker for free 3D printer onboarding course
