Controlling analog pins as digital pins in Marlin
Posted (edited) · Controlling analog pins as digital pins in Marlin
I'm interested in controlling some of the analog (ADC) pins as digital pins on the Ultimaker 2 board. I've seen that this can be done in Arduino using digitalWrite (https://www.arduino.cc/en/Tutorial/AnalogInputPins) and it also seems like it is possible to control them using the M42 command in marlin (http://marlinfw.org/docs/gcode/M042.html). Has anyone tried this or know if this is correct?
I've found the pin map for the ATmega 2560 (https://www.arduino.cc/en/Hacking/PinMapping2560) and can determine the pin locations using the Ultimaker 2 schematics. However, I'm not sure how to interface with the ADC0-11 pins (M42 PA0 S255 doesn't work). Do the analog pins have a digital pin equivalent on the Ultimaker 2 board (ex: A0 = digital pin XX)? Do I need to set this up myself in the pins.h file?
Any ideas / comments are greatly appreciated! :)
    Note that on an UM2 board, you have 3 digital pins available: Exp3 and Ext/IO (ports 13, 30 and 38 ).
    If you really need to go to analog ports, A0 is port 54 on the Mega (so M42 P54 S255 should work)
    • Like 2
    Posted · Controlling analog pins as digital pins in Marlin
    Thanks amedee, this is really helpful! I will use more than 3 pins so that is why I want to use the analog pins as well.
    • 1 year later...
    You can lookup the locations using the mega2560 pinout and the Ultimaker2 board schematics. Pins 30 and 38 are on EXT/IO which is terminal J23. Top (1,2) are ground, middle (3,4) are 5V and bottom (5,6) are P30 (PC7) and P38 (PD7).
    Edited by irishbeard
    • Thanks 1
