Select and Align Like Powerpoint
Spikey
Posted · Select and Align Like Powerpoint
Hello All,
I love your Cura and wonder if you take requests?
It's concerning lining up small items to reduce the head movement and give a nice length for the head to move. I try to line them up on the grid, but it takes ages fiddling moving items. In MS PowerPoint you can drag a square around a few items (another idea) select them and then align them up.
Is this possible?
One more if I may :)
Can Cura have the ability to have some items set at a light density, but others at a different setting? (also with and without support).
Thanks and regards
Martin
    It already has. You have to switch to "custom" mode. Now select the object you want to change the infill density of, and press the "Per model settings" tool in the toobar. Click "Select settings" and tick the "Infill density" checkbox. Now you can set the infill density for only the selected model.
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 13 replies
