Magnetic Door and Covers
Posted (edited) · Magnetic Door and Covers
Hi all, i've made an enclosure that (along with using an acetone/ABS paste) has produced great ABS prints with no delamination.
the hinges print as one (do have a file with them in two peices and used a bit of 3mm acrylic rod to join them) uses 5x10mm magnets and is attatched to the printer using the bolts already in it.
below is a google drive link which should contain all you need. (you'll need to print 14 of the corner peices and will need m3 nuts and bolts)
I laser cut out all the acrylic (5mm) pieces and have supplied the CorelDraw and DXF file
https://drive.google.com/open?id=0B8pepQJca4gHSDBrT1hCWkpvbU0IMG_20170420_074221_168.thumb.jpg.388ef29ec48c506bfcab70330f92fb4e.jpg[/media]
cheers
      • 9 replies
