We've discussed this topic a good deal
I still think it should be disabled by default
As aldo already said, it is disabled by default. However, if you have an older version where it was enabled by default and then upgrade, it's still enabled (as we don't touch preferences).
vincentbaas 19
I guess because your model is too big to fit in the build volume of your printer and you have 'Scale large models' turned in Cura's settings. In that case Cura will automatically scale the model until it fits the print volume. Not sure if this may also be a unit issue (mm vs cm etc), but otherwise you may have to split your model into multiple pieces.
DaHai8 74
Probably:
Preferences -> General -> Opening and Saving Large Models -> Scale Large Models
LePaul 316
ahoeben 1,886
It is
JakM 0
THX great help!
