usb issues
Posted (edited) · usb issues
hiya,
for reasons I don't understand, when I connect via usb my printer connects and disconnects constantly. I can't seem to find why this is.
any one know the answer?
cheers
Bex
    • 2 months later...
    Posted · usb issues
    I am working on improvements for USB printing, but that work will not be finished until Cura 2.7
    thank you I appreciate it. using Simplify3D allows me a lot of control, monitoring and faster adjustment.
    It did used to work fine but I think an update with windows has caused an issue with USB control and I can't identify it. It's as if its using the driver to reboot the printer for something that it thinks it needs to identify it in order to connect but if i click connect a number of times during the reboot it connects and all is fine again.
    I my concern is that the constant rebooting will affect the service life of the printer.
    it also allows me to level the build plate more effectively when I change nozzles without having to go through the Printer's process.
    Many thanks
    Becky
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 13 replies
