Major Jamb - first time using ABS material got an ER12C
SectaArchEng
Posted · Major Jamb - first time using ABS material got an ER12C
So I got this message - but look at the photos - I managed to get the plate out, but no clue what I have to do to get this unstuck. Of course it is Sunday, so I cannot call MatterHackers (I bought from them), do not want to hurt it anymore than it is. Any suggestions or just leave alone until I can get MatterHackers on the phone??5a333aa51a27e_2017-05-1413_50_45.thumb.jpg.877c449a1c297be9dba7b7debfa0ea9c.jpg
    Heat both nozzles to 150.
    Get a hair dryer and heat the mess up. Pull it off with some tool such as toothpicks, small screwdrivers, needle nose pliers.
    Also before you do any of that pull the head to the front of the machine. If it won't move, turn off power. It will move with power off.
    The cause of this was probably that your ABS isn't sticking well to the glass bed. Try using "abs glue" (google it) or mix pva glue (glue stick or hair spray or elmer's glue) with water and spread it over the glass and let dry before printing again.
    Also, if you got an error ER12C, it means that the print cable could have come a bit loose with the extra heat. Check your reseller or supplier on how to properly get to the cable in the print head. It is a quick and easy fix. I have managed to do so without killing the machine.
