Estimated time on CURA
Food24
Posted · Estimated time on CURA
Dear All,
my question today is on the estimated printing time by CURA.
I have printed a small pyramid with a base of 29*29 mm and an height of 22 mm.
The estimated time by CURA is about 4 minutes.
My printer finished to print after 2 min and 40 s.
It is possible that CURA has some bugs which produce this type of error ?
I have this problem when i print at very low print speed of 11.21 mm/s while when I print at 16 mm/s and 21 mm/s the estimated time are close and lower than the actual times, respectively.
Maybe there are values of minimum Feed Rate at which the printer cannot move ?
From the display of my printer (a Delta Wasp 2040) i read this setting conditions
Vmax(x,y,z,e) 250 250 250 60
Vmin 0
Vtravel min 0
Amax(x,y,z,e) 20000 20000 9000 3000
Vx,y_jerk 20
Ve_jerk 5
Accelleration 3000
A_retract (e) 3000 - - -
Estep(x,y,z,e) 85.33 85.33 85.33 400
Food24
    I would prefer an overestimation of time as you show rather than underestimation.
    I posted a similar topic and someone suggested that the quirks of individual printers may have slightly different timings on operations that cause the over-estimation. Also, if it follows some rules that are applied to other software (3D Rendering, animation, compositing) it will speed up and slow down based on a number of factors.
    But, an overestimation is good by me :) Helps me factor time better. I would feel more comfortable telling a client 4 hours and have it done in 3 than to tell them 4 hours and it take 5. I have seen people get bit by that in a very, very bad way. Even saw some loose clients.
    Dunno if this helps. But I can say that Cura had a bad rep for bad time estimations such as being 50% under (6 hours actual printing vs. 3 estimated) and have been pleasantly surprised that it is either spot on or a bit off by way of estimating a bit of extra time.
    I can say with 100% certainty that Cura has some bugs.
    But this type of error is not caused by a bug but by a mismatch between your printer firmware and the default values that Cura has to use when the printer definition does not include values about how fast your printer accelerates/decelerates while moving.
    Dear ahoeben,
    something is not clear yet.
    Are the values about how fast my printer accelerates/decelerates while moving, defined by my firmware?
    What do you mean when speak about ' mismatch between your printer firmware and the default values that Cura has to use when the printer definition does not include values about how fast your printer accelerates/decelerates while moving' ?
    I known that the installed firmware contains the parameter by which the printer will move. By using CURA we only define most printing parameters which are contrained by acceleration/deceleration, jerk etc as defined in firmware.
    Also, i would like to understand if CURA well define the movement of a DELTA printer or some bugs could be between the estimated movement and the actual one.
    Thanks
    Food24
    Posted (edited) · Estimated time on CURA
    Yes. The firmware in your printer manages a set of speed/acceleration/jerk values. And so does Cura. If the values don't match between the firmware and Cura, Cura cannot calculate a proper print time.
    I don't know, perhaps @Bagel-orb can tell.
